.NET Customisation User Guide
.NET Customisation : How to Write a CAF Addin : Addin Commands : Command Events
The Command base class provides two events BeforeCommandExecute and CommandExecuted which enable the addin writer to write code to respond to the execution of any command object registered with the CommandManager. A command object can be retrieved from the CommandManger if its Key is known and event handlers can be attached to these events.
