.NET Customisation
.NET Customisation
Introduction
: Sample Code
Sample Code
A zip file (Samples.zip) containing a number of samples using the Core/Core3D interfaces can be found in the installation directory. Each sample directory contains a number of C# source files and a Visual Studio project. Before opening and building a project in Visual Studio, set the environment variable %AVEVA_DESIGN_EXE% to include the product installation directory (this will make sure that all the project's assembly references are correct) and set %CAF_ADDINS_PATH% to include the directory where you want to build the sample (this will make sure that the project builds the example here). When running the product you also need to make sure that %CAF_ADDINS_PATH% is set to the same build directory to make sure that the example addin is loaded from here.
