AVEVA Clash Manager™ 14.3
Performance Hints
: AVEVA Clash Manager Functions
Three functions of the
AVEVA Clash Manager
can be implemented, the functions are:
Running a Clash Set as a Scheduled Batch Job
Running AVEVA Clash Manager from the Command Line Interface
Customising Clash Manager
The functions can be set to take place automatically, for example, overnight, the facility is intended to be used by administrators.
Functionality to run a clash set can be called from a PML macro, either interactively or as part of scheduled task. Refer to
for further information.
AVEVA Clash Manager provides a PML capability to start up and run clash sets from the command line.
Start AVEVA Clash Manager from the command line by instantiating the clashManagerInterface object, which will then create the core clashManager object.
!!clashManagerInterface = object clashManagerInterface()
List the available clash sets to the command line by calling the listClashSets method.
!!clashManager.listClashSets()
Run a clash set by calling the runClashSet method.
Only one clash set run can be active at a time, so call the wait method between consecutive clash set runs to chain them.
Once a clash set run has completed its last run date and comment will be visible in the
Clash Sets
form.
!!clashManager.runClashSet(!clashSetNumber is REAL, !comment is STRING)
!!clashManager.wait()
In graphical mode use the show method to display Clash Manager main form.
!!clashManager.show()
Clash Manager provides the clashManagerHandler PML object to customise specific behaviours if required on the project. Refer to
Customise AVEVA Clash Manager
