AVEVA Clash Manager provides the clashManagerHandler PML object to customise specific behaviours if required on the project. This object is created when AVEVA Clash Manager starts up and is not available until then. It can be found in the pmllib\clashmanager\objects folder.
Use the modifiedElementCheck method to add business logic to determine when a check list item should be considered modified. When the clash set property Modified Checklist Items Only is true, AVEVA Clash Manager determines if the item’s spatial map volume or geometry (including descendants) have changed since the clash set was last run.
Use the initialiseLMI method to load the Laser Modeller Interface drivers. AVEVA Clash Manager provides an out-of-the-box version that references appware supplied by the LMI vendors and should be customised where needed for individual installation requirements.
