Use the AVEVA Clash Manager Configuration window to window view and to setup facilities for features of clash management.
* The Class and Priority tabs are user-definable and can be configured for any attribute or user-defined attribute associated with the clashing elements or their owning hierarchy. (The names Priority and Class illustrate the typical configuration, and are used in this Online Guide for the tabs and for any window elements that display information derived from them.)
Upper pane showing a hierarchy with Status as the primary nodes which, when expanded, display the applicable Acceptance Rules
A popup menu is available (mouse right-click) with options of Edit, Add and Delete. This is used to edit an existing rule name, add a new rule, or remove an existing rule.
Popup menus (mouse right-click) are available from the three components of the rule expressions.
The Element Popup Menu options are:
Editing options - @element-1, @element-2, @general
Add Rule Delete
The Attribute Popup Menu options are:
Editing options - @discipline, @class, @priority, etc, and @gtype
Edit - leads to in-place editing options box Add Rule Delete
The Value Popup Menu options are:
Each rule in the discipline assignment rules consists of a number of rule expressions'. Rule expressions, which are formed of certain keywords, literals and regular expressions (wildcards), refer to Notes on Rules and Rule Expressions for further information. The first discipline with a rules whose rule expressions all evaluate true becomes the owner discipline, by default. Alternatively a set discipline keyword operator may be used in a rule expression to assign the owner discipline to that of one element or the other, or even to a third unrelated discipline.
Discipline Assignment Rules pane showing a hierarchy with Discipline
as the primary nodes which, when expanded, display the applicable Assignment Rules
A Popup menu is available (mouse right-click) with options of Edit, Add and Delete. This is used to edit an existing rule name, add a new rule, or remove an existing rule.
Popup menus (mouse right-click) are available from the three components of the Rule Expressions.
Add Rule Delete
The pane at the top of the tab enables a particular Plant Class Description and its
Attribute Value to be selected. A
Popup Menu is available (mouse right-click) with options of
Edit,
Add and
Delete. This is used to edit an existing class, add a new class, remove an existing class, or set an existing class as default. The description is user-defined, the attribute value must match the attribute value for the particular class.
The associated Up and
Down buttons are for rearranging the order of the classes, from top to bottom. The least important class is at the top; the most important at the bottom. From a pair of clashing elements, the auto-assignment process selects the discipline of the less important element to be the owner of the clash, that is, the element with the class that is nearer to the top of the list.
The Description field is for specifying the text to appear as the report column header for the attribute values.
The Attribute box enables the attribute associated with the selected class attribute value to be specified. AVEVA Clash Manager will search for the attribute on the clashing item, and if not found there, will search the owning hierarchy for it.
If Not Used is selected, the CLASS attribute does not appear in the AVEVA Clash Manager UI. CLASS is designed to produce a modest number of look-up records, when a value is used as a wildcard. An attribute, such as a NAME that would return a large number of values should not be used.
The pane on the tab displays Comments associated with a particular
Discipline. A
Add, Edit and
Delete. This is used to add a new comment, edit an existing comment, or remove an existing comment. The associated
Up and
Down buttons are for rearranging the sequence of comments.
The Discipline tab is concerned with associating the values of a selected attribute with the values of Plant discipline attributes for the purpose of automatic assignment of an owner discipline to a clash.
The pane at the top of the discipline tab displays the list of disciplines and their attribute values and, except for AVEVA Clash Manager, are read-only. For AVEVA Clash Manager, a Popup Menu is available (mouse right-click) with options to
Add, Edit,
Delete and
Set as Default. This is used to add a new discipline, edit an existing discipline, remove an existing discipline and automatically set a discipline as default. Use to create the list of disciplines and their attributes that AVEVA Clash Manager can match with the values of the specified attribute.
It is necessary to tell AVEVA Clash Manager how to identify a discipline from a clashing element’s attributes or its owner’s attributes. The Attribute box enables this functionality by specifying the particular attribute that, when evaluated, matches one of the attribute values shown in the right-hand column in the discipline table. For example, an :MMSDISC value of 'P' would normally correspond to the 'P' set as the attribute of discipline 'Piping'. AVEVA Clash Manager will search for the attribute on the clashing item, and if not found there, will search the owning hierarchy for it.
If Not Used is selected, the attribute does not appear in the AVEVA Clash Manager GUI, but the default discipline will be UNALLOCATED, unless set otherwise, by the drop-down list.
The items on the Group tab are as follows:
The Group Clashes between element pairs within +/- field and associated
mm/inch dimension radio group are for specifying the proximity of primitive clashes to be reported as a group. Because the specified values are plus or minus, the coordinate dimensions of the volume in which the clashes are considered to be a group are each twice the stated value. The default setting for the group distance between element pairs is 100mm, but it is common practice to have this value changed to 2000mm to make the clash grouping more effective. The decision to change the distance should be done only in consultation with the project discipline lead designers. The distance setting can be changed at any time during the project life cycle, but the clash groups must then be recomputed. Making fundamental changes to the group settings mid-project is not a recommended practice.
The Default Group Level drop-down lists are used to specify the level in the hierarchy at which the clashes are grouped within the appropriate discipline. For example, clashes within a pipe, may be reported at primitive level, at the branch level or at the pipe level. The defaults are PIPE-PIPE, EQUI-EQUI, STRU-SCTN, HVAC-HVAC, REST-REST and normally these are used. Clashes in other disciplines such as Hull and Room Design do not default to single levels and are handled by Group Rules described below.
The pane at the bottom of the Group tab is for specifying exceptions to the default group levels. The exceptions are defined under headings of
GTYPE,
Attribute, Value and
Group Level. A
Add, Edit and
Delete, used to add a new GTYPE and details, edit an existing GTYPE details, or remove an existing record.
Up and
Down buttons at the right-hand side of the pane are used to position the highlighted record in the list and hence determine its priority.
A Group Rule with GTYPE * will allow clashes to be grouped at the level of any type entered under
Group Level. For example, to group clashes with Hull objects at any of HPANEL, CPANEL, BLEVEL or BBLOCK, create four rules with entries as:
GTYPE *,
Attribute and
Value left blank,
Group Level HPANEL in the first rule,
Group Level CPANEL in the second rule, and so on.
Other examples for Cableway and Room Design objects are shown in the picture above. The entry with GTYPE * and
Group Level CWAY will group all clashes below cableways to the owning cableway. The entry with
GTYPE * and
Group Level ROOM will group all clashes below rooms to the owning room. The entry with
GTYPE CTWALL and
Group Level CTWALL will group clashes with constant thickness walls at that level, but note that clashes with CTWALL objects below ROOM objects will be grouped at ROOM level due to the earlier rule.
The Gtype/Tracking tab enables the administrator to specify which MDBs and controlled GTYPEs are to be included in a Track Changes operation. Additionally, it provides facilities for specifying Tracking Selection Rules that further restrict the range of controlled GTYPEs to be included in the operation.
The top pane displays a listing under headings of GTYPE and
State. The listing is used to present a list of available GTYPEs and to enable certain of them to be made Controlled or Uncontrolled. (Only a Controlled GTYPE is the subject of a Track Changes operation.)
The Esc key can be used to abort the entry in in-place windows.
The Priority tab enables the values of an attribute to be associated with the values of the Plant priority attribute for the purpose of automatic assignment of a priority to a clash.
The pane at the top of the tab enables a particular Priority Description and its
Add,
Editing,
Delete. This is used to add a new priority, edit an existing priority, or remove an existing priority. The description is user-defined, the attribute value must match the attribute value for the particular priority.
Down buttons are for rearranging the order of the priorities, from top to bottom. The least important priority is at the top; the most important at the bottom. From a pair of clashing elements, the auto-assignment process selects the discipline of the less important element to be the owner of the clash, that is, the element with the priority that is nearer to the top of the list.
The Attribute box enables the priority attribute to be selected. AVEVA Clash Manager will search for the attribute on the clashing item, and if not found there, will search the owning hierarchy for it. If
Not Used is selected, the PRIORITY attribute does not appear in the AVEVA Clash Manager GUI. Note that PRIORITY is designed to produce a modest number of look-up records, when a value is used as a wildcard. An attribute, such as a NAME that would return a large number of values should not be used.
Discover automatically produces a list of priority descriptions and attributes that are applicable to elements in clashes that have been discovered by AVEVA Clash Manager. Each Description of the various priorities is formed by a concatenation of the attribute name followed by the particular attribute value. For example, for an attribute 'priority' and a value 10, the description is 'priority 10'. Each listed attribute value is available as a Regular Expression wildcard (refer to
Notes on Wildcards for further information) for use in assignment and acceptance rules. The attribute values are preceded by ^ and followed by $ to make sure that only complete strings are matched, for example, ^10$.
Following operation of the Discover button to determine all available values, the resultant data can be edited to give acceptable ranges of priorities. For example, returned priorities with values of ^10$ through ^19$ could be edited to a single description Low Priority with a value ^1[0-9]$.
The Project Title, Client, Project Number, Project, Userid, Password fields at the top of the tab are for entry of those project details.
Use the Display Units section to select the units in which the values are to be displayed in AVEVA Clash Manager.
The Apply Group Changes to Clash Detail drop-down list enables the administrator to specify the policy for the project. The selection made here determines whether or not the user can use the facility on the
AVEVA Clash Manager Options window to choose whether or not group changes are applied to clash details within a group.
Always - group changes are always applied and the user cannot change the policy (recommended)
Never - group changes are never applied and the user cannot change the policy
Free - the user can choose whether or not group changes are applied.
The items in the Project Field are for selecting an attribute, the value of which is to be added to the clash report for each clashing item. This additional data is useful for filtering and sorting purposes in the main body of the report.
The Attribute Name field is for specifying the name of the attribute, for example: AREA. AVEVA Clash Manager will search for the attribute on the clashing item, and if not found there, will search the owning hierarchy for it.
The Description field is for entering the attribute value that appears in the Clash Report.
The Default field is for specifying a default value for the attribute if the attribute is not set.
An example of how an attribute can be used is as follows. Many companies use PURPose as the Attribute Name and the
Zone radio button selected for capturing the description of a ZONE’s content over and above the naming convention. The ZONE is named with the Piping Specification PSPE and the
Attribute Name PURPose is given a
Description PROC for Process Piping and UTIL for Utility Piping. AVEVA Clash Manager then filters the clash report based on these values.
The Class, Discipline and Priority tabs have groups of items similar to those in the Project Defined Field box and which have similar functionality.
The Security tab displays one of four panes for setting Security Levels (namely,
Status,
Owner discipline,
Check CE,
Comments and
User Access Levels), The particular security level pane is selected by clicking the appropriate icon displayed in the
Security tab window.
The elements displayed in the centre of the pane, depend on whether the pre-defined or custom settings are being used. When pre-defined settings are being used, a slider control enables the security to be set to one of the five states namely, High,
Medium High,
Medium,
Medium Low and
Low. The name of the selected state and a narrative statement of its effect appear to the right-hand of the slider control. The default state for each security level is
Medium. When custom settings are being used, the pane displays the message: 'Custom - To change the settings, click Custom Level - To use the recommended settings, click Default Level'.
At the bottom of the pane are two buttons. The Custom Level button leads to the 'AVEVA Clash Manager - Security Settings' window, at which the pre-defined settings for the particular Security Level can be superseded by custom (user-defined) settings. The
Default Level button is for selecting the default state.
Clash Check CE automatically creates and runs a personal Clash Set. A suitable level of security is important in order to maintain some control of the growth of Clash Sets
User membership of a discipline is granted by dragging the discipline and dropping it onto a user name. Alternatively, the discipline can be selected from a right click menu. Similarly, a user name may be dropped onto a discipline.
A checkbox is located against the left-hand side of each user and discipline symbol. Supervisor rights are shown in the tree by a checked box against the discipline under the user and by a checked box against the user under the discipline.
From the Security tab of the
AVEVA Clash Manager - Configuration window, select
Custom Level to display the
AVEVA Clash Manager - Security Settings window. Use the window to specify custom (user-defined) settings that can take the place of the pre-defined settings for a particular Security Level, refer to
Access Rights for further information.
The pane at the top of the tab displays the various status details under Description, State and
Access. A
Add,
Edit,
Delete and
Set Default.
For standard status, the Description and
State entries are identical, namely, Unknown, Unapproved, Pending, Conditional and Approved, and are read-only. The standard status values are explained below:
For user-defined status, the Description can be any text; the
State must represent a standard status.
The Access defines who can apply the particular status to a clash or change a clash from the particular status to another. This access restriction is in addition to any set at the Security tab. Access can be set to a discipline, in which case, only a user who has supervisor rights to that discipline can change the status. The alternative access settings are blank or 'Any', both of which signify that there is no access restriction, other than that set at the Security tab.
The Default Status (for New Clashes) drop-down list is for specifying the status to be applied to new clashes that are not automatically accepted.
Use the AVEVA Clash Manager - Test Rules window to test assignment and acceptance rules before they are applied to the whole 3D model by the Recomputation process. The window enables a subset of existing clash records to be selected in order to display what would happen if the current rules were applied to the 3D model. The window is intended to aid configuration; it does NOT allow the evaluated status or discipline of the selected clash records to be saved.
Index (clash details only)
Blank after Query. Populated after rule evaluation. Shows owner discipline as assigned by the new rules. The name of the rule is shown for NEW clashes only.
Blank after Query. Populated after rule evaluation. Shows the status as applied by the new acceptance rules. The name of the rule is shown for NEW clashes only.
Populated after Query, shows the clash level.
Populated after Query, shows the clash type.
Blank after Query. Populated after rule evaluation, shows a narrative description of the clashing elements.
The procedure for using the window is firstly to select clash group or detail and enter an element name and wildcard to represent elements that will be affected by the updated rules. Initiate the Query and then check the displayed records to make sure that they represent the required typical elements. If they do not, re-enter element and wildcard details and re-query the data. When the records are as required, apply the new rules and check whether the results are as required. Close the window by clicking on the
X at the top right-hand corner. Take action at the
AVEVA Clash Manager - Configuration window to correct or implement the new rules, as appropriate.
