The Manually Load Clash Files functionality is intended to be used if and when the normal process of reading desclash output files, post-processing the data, and loading it into the AVEVA Clash Manager Database is interrupted or fails, or if the RDBMS becomes unavailable through network or hardware faults. This action avoids wasting the possibly considerable time already spent running desclash.
Displays the Load Clash Manage Data Files part of the
AVEVA Clash Manager - Administrator window, Used following a failure during clash file handling, by loading desclash output files to replace any that are partially loaded following a system failure.
