For all disciplines select the All check box, repeated use of the All check box turns on or off all disciplines.
The Filter drop-down list defaults to the report being filtered to the clash owner. The other options enable discipline filtering for either of the clashing elements and the owner. The All check box is used to check all disciplines.
Use to select the areacodes of clashes to be included in the report. For all codes select the All check box.
Use to select the clash sets to be included in the report. For all sets select the All check box. The clash sets are listed with the most recently run clash set at the top.
Specific Element wildcards may be separated by a vertical bar, for example,
%42% %43% | %44% %45% matches any clash where one element name contains 42 or 43 and the other contains 44 or 45 |
Project-define (default
Class) list with check boxes for 'ALL', 'Unknown', 'Fabricated' and 'Unclassified'. |
Use to select the Status of clashes to be included in the report, or to select Unknown status. For all Status, select the ALL check box.
The Discipline and Status check boxes called Automatically Set and Manually Set are for selection of whether the report is to include values automatically set by Assign/Accept rules and/or values manually set.
Select Any Date, New clashes, Clashes between selected dates, Clashes during a selected preceding period.
Two drop-down lists for comparisons of Group Status with worst detail and Group Level/Type with worst detail.
All items on the Advanced Filter tab are ignored unless this check box is selected. When the check box is checked, only clash groups and details that satisfy EVERY filter selection made on the Advanced tab together with the basic filter selection are reported.
