The name of the MDB to be used within the AVEVA Clash Manager.
A list of named elements or wildcards covering a range of elements and their attributes from within the specified MDB that window the Obstruction List. The popup menu option Evaluate (refer to Evaluate for further information) may be used to verify the resultant Obstruction list is as required.
A list of named elements or wildcards covering a range of elements and their attributes from within the specified MDB. This Exclude List specifies members that are to be excluded from the Obstruction list. The popup menu option Evaluate (refer to Evaluate for further information) may be used to verify that the resultant Exclude list is as required.
A list of named elements or wildcards covering a range of elements and their attributes from within the specified MDB that window the check list for the clash detection. The popup menu option Evaluate (refer to Evaluate for further information) may be used to verify that the resultant Check list is as required. The TYPE of Checklist elements must be consistent, all ZONEs or all PIPEs and so on.
Respectively have the same functions as the Add, +CE and Delete functionality of the popup menu (refer to Add, + CE and Delete for further information).
The functionality on the Extents tab is used to specify the overlap, gap and clearances.
The functionality on the Limits tab is used to specify the co-ordinates of the space occupied by the clash set.
The functionality on the History tab displays the dates and details of previous clash runs.
Some AVEVA Clash Manager ADMIN options, including merge (compress) and reconfigure, flag every element as having possibly changed geometry. To obtain maximum benefit from Clash Check Modified Elements Only a full Clash Check will need to be executed after use of these options.
Confirms selections made and closes the AVEVA Clash Manager - Clash Set window.
Ignores selections made and closes the AVEVA Clash Manager - Clash Set window.
Adds items or expressions to the Obstruction, Exclude or Check List, displays in the AVEVA Clash Manager - Clash Set Data window.
Edits expressions selected in the Obstruction, Exclude or Check List, displays in the AVEVA Clash Manager - Clash Set Data window.
Adds the CE to the Obstruction, Exclude or Check List, displays in the AVEVA Clash Manager - Clash Set Data window.
Deletes the selected item from the Obstruction, Exclude or Check List, displays in the AVEVA Clash Manager - Clash Set Data window. The item is not deleted from the 3D model.
Displays the overall list when its wildcards are expanded, displays the Evaluate window, which displays a consolidated listing of the results of querying the 3D model and expanding the expressions in the particular list.
Closes the Evaluate window.
Progress bar and
adjacent indications |
During the clash run, a Loading item number is continually updated.
