From the grid pane of the AVEVA Clash Manager Project Connections window populated with a list of connections, use the right click menu to:
That there are two distinct collations used, one for the server instance and one for the project. The collation of SQL Server Instance must be case-insensitive, Latin1_General_CI_AS is a suitable choice. The collation used when creating a project should be case-sensitive as the underlying application is case-sensitive.
A FREE user or a member of the DESADMIN team has an opportunity to edit the connection details by selecting Connection Wizard on the Login window.
The SQL Server user password can be changed externally, in that case, select Edit Connection from the AVEVA Clash Manager - Clash Manager Project Connections window to update the clash manager configuration.
A FREE user or a member of the DESADMIN team can edit the connections, by selecting Connection Wizard on the Login window.
