Use the Update Clash Status functionality to update the clash status of the CE, Elements or MDB, from the
AVEVA Clash Manager window, select
View > Status Control to display the
AVEVA CLash Manager - Clash Status Update window.
Use the functionality available from the Database Options part of the
AVEVA Clash Manager Update Clash Status window, to select objects from the
AVEVA Clash Manager tables that can have clash status set against them:
Use the Populate Form functionality to display all the writable objects names, type and clash statuses extracted from the
AVEVA Clash Manager tables.
Select Update Status to set the status against their equivalent objects in the databases. A log file called clashStatus.log is produced in the
AVEVA_DESIGN_USER directory to record any warnings or errors that may occur. This file will be overwritten with each update. The results can be viewed in the standard status control grid.
