Supports User Guide
Special Support : Lighting Support
You are prompted to Identify Lighting Equipment you wish to support
The Select Required Template window displays all of the available lighting support templates for the selected light fitting. Refer to Select Required Template for further information.
Select the required template, for example, Lighting hanger (wall mounted), on the Select Required Template window and click Cancel to close the window.
The functionality of the Support Editor window is explained. Refer to Support Editor for further information.
