Supports User Guide
Ancillaries : Ancillary
To create an ancillary, on the Stand Alone Supports gallery, click Ancillary.
You are prompted to Identify element you wish to support
The Ancillary Selection window displays a filtered list of all available/unavailable anchors for the selected pipe bore. Refer to Ancillary Selection for further information.
You must select an ancillary from the list of available ancillaries. For example, click XAT001 - Pipe shoe for N.B. 3/4” to 20” and click OK to display the Support Editor window.
Click Cancel to discard any changes and close the Ancillary Selection window.
The functionality of the Support Editor window is explained. Refer to Support Editor for further information.
If you create an anchor on a vertical pipe or a vertical framework section, the Datum attachment direction window displays by default. Refer to Datum Attachment Direction for further information.
