Supports User Guide
Ancillaries : Anchor
To create an anchor, on the Stand Alone Supports gallery, click Anchors.
You are prompted to Identify element you wish to support
The Ancillary Selection window displays a filtered list of all available/unavailable anchors for the selected pipe bore. Refer to Ancillary Selection for further information.
You must select an anchor from the list of available anchors. For example, click XAN02 - Pipe Shoe Anchor and click OK to display the Support Editor Window.
Click Cancel to discard any changes and close the Ancillary Selection window.
The functionality of the Support Editor window is explained. Refer to Support Editor for further information.
If you create an anchor on a vertical pipe or a vertical framework section, the Datum attachment direction window displays by default. Refer to Datum Attachment Direction for further information.
