If you create a support on a vertical pipe or create an ancillary on a vertical framework section, the Datum attachment direction window displays by default. Refer to Datum Attachment Direction for further information.
Press ESC to create the support using the default dimensions, no connections are made to steelwork.
Press ESC to create the support using the dimensions gained from the position of the identified element.
By default, connections are made to the identified supporting elements which results in some Dimensions fields becoming inactive. Refer to Supports Connectivity for further information.
