Supports
Supports Tools
: View Support Dimensions
Displays support dimension tags in the 3D view.
You are prompted to
Pick Support :
The prompt does not display if the support is already selected.
Click to identify the support using a cursor pick in the 3D view.
You can continue to select additional supports.
Press
ESC
to end the selection process and display the dimension tags for the selected supports.
Repeat the command to remove the dimension tags from the 3D view.
If the currently selected element is not a support, a
Message
window displays instructing you to pick a valid support member.
