You are prompted to Pick Support or <ESC> to finish :
Select from the drop down list to apply a trimmer requirement to the currently selected support. A confirm window displays asking you to OK the addition. Click Yes to add the trimmer steel requirement.
Select from the drop down list to remove a trimmer requirement from the currently selected support. A confirm window displays asking you to OK the deletion. Click Yes to delete the trimmer steel requirement.
