Supports
Supports Tools
: Add Pipe Stress Interface Data
Sets the pipe stress interface data for an ancillary.
You are prompted to
Identify ancillary to modify or <ESC> to finish :
The prompt does not display if the ancillary is already selected.
Click to identify the ancillary using a cursor pick in the 3D view to display the
Data
window.
CE
Click to select the existing ancillary as the current element.
The ancillary name displays in the field.
Identify
Click to identify an ancillary using a cursor pick in the 3D view.
You are prompted to
The
Ancillary
field is populated with the name of the identified ancillary.
You can update the data attribute fields for the ancillary.
Click
Apply
to apply the modifications to the
Data
window.
Click
OK
to apply the modifications and close the
Data
window.
Click
Cancel
to discard any inputs and close the
Data
window.
