You are prompted to Pick Support :
The Select Support field is populated with the name of the identified support.
Click to remove a spool. A Confirm window displays asking you to OK the action. Click Yes to remove the spool, the content of the spool is added to Spool 1.
You are prompted to Identify GENSEC
