You are prompted Pick SNIPE edge or leg of end of angle where you want it to be created:
The 3D view indicates the position of the Snipe and that it has not been created. Click Apply to create the Snipe.
Click Auto to identify the end of the support structural member to be associated with the snipe using a cursor pick in the 3D view.
You can continue to identify additional support structural member ends to be associated with Snipes.
Click Auto again to disable the functionality.
Select the Start option button to associate the start of the currently selected support structural member with the Snipe.
Select the End option button to associate the end of the currently selected support structural member with the Snipe.
Select the Top option button to associate the top of the currently selected support structural member with the Snipe.
Select the Left option button to associate the top of the currently selected support structural member with the Snipe.
Click Lock to lock the values of the Snipe Length and Snipe Height fields. If you input a value into one of the fields, the other field is populated with the same value, by default
Click Lock again to disable the functionality.
