You are prompted to Pick Support :
The Support field is populated with the name of the identified support.
Allows you to define the note position. Refer to Modify Note Position for further information.
Alternatively, select the position axis from the Position drop-down lists, choose from East/West, North/South and Up/Down. You can then input the explicit position values in the Position fields.
