You are prompted to Pick Support :
The Select Support field is populated with the name of the identified support.
Select ON to include the ancillary on the isometric material list.
Select OFF to exclude the ancillary from the isometric material list.
Select Dotted with Dims to include the ancillary on the isometric drawing representation and display as dotted with dimensions.
Select Dotted without Dims to include the ancillary on the isometric drawing representation and display as dotted without dimensions.
Select ON to include support tags on the isometric drawing representation.
Select OFF to exclude support tags from the isometric drawing representation.
Select from the drop down list to modify the Material Column for all ancillaries in the list.
