Supports
Supports Tools
Drawing Tools
: Drawing Comment
Drawing Comment
Creates, modifies and removes a drawing comment associated with a support.
You are prompted to
Identify Support to modify the drawing comment :
The prompt does not display if the support is already selected.
Click to identify the support using a cursor pick in the 3D view to display the
Modify Drawing Comment
window.
CE
Click to select the existing support as the current element. Alternatively you can input the support name in the field.
Identify by Cursor
Click to identify the support using a cursor pick in the 3D view.
You are prompted to
Identify support to modify the drawing comment :
Comment
Input, modify or delete the data in the field.
Click
Apply
to modify the drawing comment or
Cancel
to discard any changes and close the
window.
