Supports
Supports Tools
: Supports Wizard
Supports Wizard
Quickly identifies pipes, structural sections, and equipment within a specified area of the 3D view.
Choose Working Element
Click to identify the element to use as the volume origin.
You are prompted
Identify element to use as a volume
Pipes
Select the option button to add pipes to the 3D view.
Steelwork
Select the option button to add structural sections to the 3D view.
Equipment
Select the option button to add equipment to the 3D view.
Reach
Input a value in the field to identify an area to search in the 3D view, measured from the identified element used as the datum of volume.
The reach box indicates the extent of the search in the 3D view, defined with a red border. You can modify the value of the field to make the reach box smaller or larger. The position of the reach box is shown in the
From
and
To
parts of the
Supports Wizard
window
Add Elements within Reach
Click to add all defined elements within the reach box to the 3D view.
Click
Cancel
to close the
Supports Wizard
window.
