Supports
Supports Tools
: Lock/Unlock Support
Lock/Unlock Support
Locks or unlocks a support for modification. When a support is locked it cannot be modified or deleted.
The following conditions must be met to enable the lock functionality:
The support must not be currently claimed by another user
The support must not be located in a read only database
A successful DAC check can be carried out on the support
Lock Support
You are prompted to
Pick Support or <ESC> to finish:
The prompt does not display if the support is already selected.
Click to identify the support(s) to be locked using a cursor pick in the 3D view.
Press
ESC
to lock the selected support(s).
Unlock Support
You are prompted to
Click to identify the support(s) to be unlocked using a cursor pick in the 3D view.
Press
ESC
to unlock the selected support(s).
