Supports User Guide
Supports Tools : Copy Support
You are prompted to Identify source support to copy or <ESC> to finish :
You are prompted to Identify tube of pipe to add DATUM ancillary of the support or <ESC> to finish :
You can continue to click the pipe to copy additional supports. The Distance value can be modified between each copy.
Press ESC to finish copying supports.
