Supports User Guide
Supports
Depending on the selections made from the Supports tab, you are presented with further windows prompting for input and options allowing for the workflow to continue.
You are not able to make any selections from the Supports tab if the correct database hierarchy has not been configured beforehand. For example certain support elements must reside below other elements in the database hierarchy.
