Supports User Guide
Hanger : Steelwork Hanger : Double to Beam Hanger
You are prompted to Identify tube of datum pipe or support
You are then prompted to Identify first steelwork member to connect hanger to
You are then prompted to Identify second steelwork member to connect hanger to
Select VH T4 M1 B14 - Variable Hanger NPS 3 - 24 on the Template Hanger Creation window and click OK to display the Ancillary Selection window.
Click Cancel to discard any changes and close the Template Hanger Creation window.
The Ancillary Selection window displays all of the available/unavailable ancillaries for the selected pipe bore. Refer to Ancillary Selection for further information.
Select XAT003 - Clamp on pipe shoe for N.B. 3/4” to 20” on the Ancillary Selection window and click OK, to display the Support Editor window.
Click Cancel to discard any changes and close the Ancillary Selection window.
The functionality of the Support Editor window is explained. Refer to Support Editor for further information.
