ISODRAFT
Material Control File
File Format
: Individual Formats for Each Type of Information Record
The following tables show the information which is output for each type of record, listed in the word order in which it is output. A
word
in this context means one specific item of information.
The effect of these formats on the output will be most easily seen by studying the output sample listing given in
Example of a Material Control File Output
Each type of record has provision for up to 14 words, each word having an integer field of length five. Only the number of words actually used for a particular type of record is listed in the corresponding table.
Record Number 50:
Spool Count, Drawing Number and Number of Drawings
Record Number 60:
Centreline Length Summary
Each type 60 record can accommodate up to six sizes of tube (i.e. up to six different nominal bores). If a drawing sheet contains more than six bore sizes, more than one type 60 record will be created. These will be written consecutively to the file.
The dimensional units specified by word 2 in record 60 are applicable to all subsequent records up to the next set of header information; i.e. up to the -6 identifier for the next pipeline.
Record Number 100:
Tube
Record Number 200:
Fittings
Record Number 300:
Flanges
Record Number 400:
Gaskets
Record Number 500:
Bolts
Record Number 600:
Valves and In-line Item
s
Record Number 700:
Instruments
Record Number 800:
Supports and Hangers
Record Number 900:
Miscellaneous Component Record with Unit Quantity
Record Number 1000:
Miscellaneous Component Record with Length Quantity
