ISODRAFT
Material Control File
: Create a Material Control File
To create a basic material control file, use the command:
MATControl
filename
where
filename
is the name of a file in the operating system directory. If a file of the given name exists, new data will be added to the end of it. If
filename
does not exist, a new file is created.
The format of the material control file is described in
File Format
The user can create a more detailed material control file by using the EXTENDED command as follows:
MATControl
filename
EXTended
The extended material control file contains the information contained in the basic material control file (refer to
File Format
), plus the following:
Part numbers (in word 8 of component records)
Item descriptions (as record -21)
File header with:
-5 record (originating program/version)
-3 record (title block information)
Always delete files once the data has been transferred to the external material control system, to avoid wasting disk space.
