ISODRAFT
Alternative Texts
: Title Block Area
Title Block Area
250 ‘DATE’
The actual date is appended automatically in the required format (refer to
DATE
This Atext also uses Atexts 258 to 269, inclusive, if the date format is set to UK.
251 ‘PROJECT NO’
Used if the project number is to be plotted (refer to
PROJECTNUMBER
252 ‘BATCH REF’
The AVEVA E3D™ zone name is appended automatically.
253 ‘PIPING SPEC’
The value of the attribute SPEC from the element PIPE is appended automatically.
254 ‘ISS’
The value of the attribute REV (i.e. the revision level) from the element PIPE is appended automatically.
255 ‘DRG’
Used only when a pipe is split over multiple drawing sheets. This Atext is used in conjunction with Atext 256 (in the format DRG 1 OF 2) or with Atext 276 (in the format CONT. FROM DRG 1).
256 ‘OF’
Used in conjunction with Atext 255.
257 ‘SPL’
Denotes a SPOOL drawing. Sequential numbering, starting at 1 for each pipe, is appended automatically.
258 ‘JAN’
259 ‘FEB’
260 ‘MAR’
261 ‘APR’
262 ‘MAY’
263 ‘JUN’
264 ‘JUL’
265 ‘AUG’
266 ‘SEP’
267 ‘OCT’
268 ‘NOV
269 ‘DEC’
258 ‘JAN’ to 269 ‘DEC’ All used in conjunction with Atext 250 (for UK date formats).
270 ‘THERMAL INSULATION SPEC’
The value of the attribute ISPE of the element PIPE is appended automatically.
271 ‘TRACING SPEC’
The value of the attribute TSPE of the element PIPE is appended automatically.
272 ‘PAINTING SPEC’
The value of the attribute PTSP of the element PIPE is appended automatically.
