ISODRAFT
Symbol Keys
: INST Symbol Keys
INST Symbol Keys
Component Description
SKEY
Plotted Symbol
P-points
Note
Instrument
II**
1,5
Instrument - Angle
IA**
1,2,5
Instrument - Offset
IO**
1,3
Instrument - Return
IR**
1,4
Instrument - Dial
IDPL
6
Instrument - Dial
Flanged
IDFL
6
Orifice Plate
OP
Restrictor Plate
RP
Rupture Disk
DR
Valve - Angle Relief/Vent
RA**
1,5
Valve - Angle Pressure Reducing
XA**
1,5
Valve Control
CV**
1,5
Valve - Angle Control
CA**
1,5
Valve - 3 Way Control
C3**
1,5
Valve - 4 Way Control
C4**
1,5
Valve - Control Square Indicator
SV**
1,5
Valve - Angle Control Square Indicator
SA**
1,3
Valve - 3 Way Control Square Indicator
S3**
1,5
Valve - 4 Way Control Square Indicator
S4**
1,5
Valve - Control Motorised Indicator
MV**
1,5
Valve - Angle Control Motorised Indicator
MA**
1,5
Valve - 3 Way Control Motorised Indicator
M3**
1,5
Valve - 4 Way Control Motorised Indicator
M4**
1,5
Valve - Control Hand Indicator
HV**
1,5
Valve - Angle Control Hand Indicator
HA**
1,5
Valve - 3Way Control Hand Indicator
H3**
1,5
Valve - 4Way Control Hand Indicator
H4**
1,5
Valve - Pressure Reducing
XV**
1,5
Valve - Relief/Vent
RV**
1,5
Level Gauge
LG**
1
One-Level Multiport
Valve
JL**
1,7
One-Level Multiport Valve
JT**
1,7
Two-Level Multiport Valve
JB**
1,7
JK**
1,7
JC**
1,7
JV**
1,7
JA**
1,7
JP**
1,7
JE**
1,7
JO**
1,7
Three-Level Multiport Valve
JW**
1,7
JY**
1,7
JU**
1,7
JM**
1,7
JX**
1,7
JN**
1,7
JZ**
1,7
JG**
1,7
Notes:
1.
Replace the ** characters in the symbol key with one of the following end condition identifiers:
BW for butt weld
CP for compression
SW for socket weld
FL for flanged
SC for screwed
PL for plain
2.
To use this symbol, the p-points must be arranged as shown in the following diagram:
3.
That the horizontal offset may be zero; i.e. P0, P1, P2 and P3 may be coplanar.
4.
That the horizontal offset may be zero; i.e. P0 and P1 (and similarly P2 and P3) may be coincident.
5.
If an orientation p-point (P3) is present in the point set and is oriented away from the XYZ axes, then the orientation of this p-point will be shown on the isometric.
6.
Instrument dials can have a P3 with an unset bore for orienting the dial. This p-point will normally be positioned perpendicular to the dial face, on the dial axis. A message will be output near the component showing the orientation of P3.
7.
P-Point 11 is the Spindle attachment point and its PURP attribute should be set to 'SPIN'. These Multiport Valves may have up to two flushing/draining connections: -
These must be P-Point 9 and P-Point 10.
The isometric will only show a symbolic line and a note CONT TO "name" for each connection.
There will be no materials or isometric representation of the branch connection to these points.
