ISODRAFT
Symbol Keys
: COUP Symbol Keys
COUP Symbol Keys
Component Description
SKEY
Plotted Symbol
P-points
Note
Nipple - Screwed
NRSC
Nipple - Screwed
NBSC
Coupling -
Compression
COCP
Coupling - Screwed
COSC
Coupling - Socket
Weld
COSW
Half Coupling
- Screwed
CFSC
Half Coupling
- Socket Weld
CFSW
Butt Weld Elbolet
CEBW
1
Socket Weld Elbolet
CESW
1
Screwed Elbolet
CESC
1
Centre Flange
CPCF
Watertight bulkhead and deck
CPWP
Welded sleeve thru pipe
CPWT
Welded sleeve and pipe
CPWW
1.
The dimensions of these components depend upon plotted leg length. The default plotted leg length is 9mm, but the user can set this to a different value using the LEGLENGTH command. The minimum value the user can set is 6mm.
