ISODRAFT Reference Manual
Recommendations for Importing DXF files from ISODRAFT into MicroStation : Fonts : Utilities/Install Fonts Menu
To keep them separate the required fonts should be installed into a new font library called, perhaps, E3D.rsc which should be placed with the supplied libraries in the path:
Now use the Element > Text menu to check the installation. The newly installed fonts should be visible together with the font numbers assigned by MicroStation to the new fonts.
1.
Use the Utilities > Install Fonts menu to give the Font installer dialog box.
2.
Select font file on destination and change to desired font number.
