HVAC
Administrator Guide
User Definable Stiffeners
Prior to VERSION 12.0 the stiffeners available for use on the HVAC components were a fixed set of stiffeners, such as 25, 30, 40 etc. all defined in the macro MSTIFSIZ. The HVAC Administrator is now able to define the stiffener sizes and codes.
There is a new section (SECT) in the HVAC catalogue database.
/CADCHVACCATA-Stiffeners
These sections hold dataset elements (DATASET) for each stiffener, and each dataset has 7 data elements, …/DESC …/CODE …/HVSA …/HVSB …/HVSC …/CONFIG …/SHAPE
Example:-
/CADCHVACCATA-Stiffeners/25
DESC '25x25x3 Angle'
FUNC '25'
/CADCHVACCATA-Stiffeners/25/DESC
DKEY DESC
PTYP TEXT
PPRO ( '25x25x3 Angle' )
DTIT 'Description'
/CADCHVACCATA-Stiffeners/25/CODE
DKEY CODE
PTYP TEXT
PPRO ( '25' )
DTIT 'Code'
/CADCHVACCATA-Stiffeners/25/HVSA
DKEY HVSA
PTYP REAL
PPRO ( 25 )
DTIT 'A Dimension'
/CADCHVACCATA-Stiffeners/25/HVSB
DKEY HVSB
PTYP REAL
PPRO ( 25 )
DTIT 'B Dimension'
/CADCHVACCATA-Stiffeners/25/HVSC
DKEY HVSC
PTYP REAL
PPRO ( 3 )
DTIT 'C Dimension'
/CADCHVACCATA-Stiffeners/25/CONFIG
DKEY CONF
PTYP TEXT
PPRO ( 'EXTERNAL' )
DTIT 'Internal/External configuration'
/CADCHVACCATA-Stiffeners/25/SHAPE
DKEY SHAP
PTYP TEXT
PPRO ( 'L' )
DTIT 'Stiffener shape'
The information in these data elements defines a stiffener and all its relevant details used for stiffener creation. The standard stiffener sizes and codes available currently are:
Stiffener
25
$<25x25x3 Angle$>
25 25 3
Stiffener
30
$<30x30x4 Angle$>
30 30 4
Stiffener
40
$<40x40x4 Angle$>
40 40 4
Stiffener
50
$<50x50x5 Angle$>
50 50 5
Stiffener
60
$<60x60x6 Angle$>
60 60 6
Stiffener
65
$<65x65x6 Angle$>
65 65 6
Stiffener
70
$<70x70x7 Angle$>
70 70 7
Stiffener
75
$<75x75x7 Angle$>
75 75 7
Stiffener
80
$<80x80x8 Angle$>
80 80 8
Stiffener
90
$<90x90x9 Angle$>
90 90 9
Stiffener
100
$<100x100x10 Angle$>
100 100 10
Stiffener
6550
$<65x50x6 Angle$>
65 50 6
Stiffener
7550
$<75x50x6 Angle$>
75 50 6
Stiffener
8060
$<80x60x6 Angle$>
80 60 6
Stiffener
10065
$<100x65x6 Angle$>
100 65 6
Stiffener
10080
$<100x80x8 Angle$>
100 80 8
Stiffener
253
$<25x3 Flat bar$>
25 0 3
Stiffener
254
$<25x4 Flat bar$>
25 0 4
Stiffener
304
$<30x4 Flat bar$>
30 0 4
Stiffener
305
$<30x5 Flat bar$>
30 0 5
Stiffener
354
$<35x4 Flat bar$>
35 0 4
Stiffener
405
$<40x5 Flat bar$>
40 0 5
Stiffener
505
$<50x5 Flat bar$>
50 0 5
Stiffener
606
$<60x6 Flat bar$>
60 0 6
Stiffener
6010
$<60x10 Flat bar$>
60 0 10
Stiffener
8010
$<80x10 Flat bar$>
80 0 10
Stiffener
8012
$<80x12 Angle$>
80 0 12
Stiffener
303
$<30x30x3 Angle$>
30 30 3
Stiffener
608
$<60x60x8 Angle$>
60 60 8
Stiffener
801
$<80x80x10 Angle$>
80 80 10
Stiffener
7638
$<76x38 Channel$>
76 0 38
Stiffener
10251
$<102x51 Channel$>
102 0 51
Stiffener
12763
$<127x63 Channel$>
127 0 63
Stiffener
15276
$<152x76 Channel$>
152 0 76
The code above are numbers such as 25, 30, 40 etc. but a code can be any text such as abc123, xyz789 etc.
