HVAC Administrator Guide
User Definable Joints Set
25x25x3 (1x1x1/8) equal angle section joint
30x30x3 (11/4x11/4x1/8) equal angle section joint
30x30x4 (11/4x11/4x3/16) equal angle section joint
40x40x4 (11/2x11/2x3/16) equal angle section joint
45x45x4 (13/4x13/4x3/16) equal angle section joint
50x50x5 (2x2x3/16) equal angle section joint
60x60x6 (21/4x21/4x1/4) equal angle section joint
60x60x8 (21/4x21/4x5/16) equal angle section joint
65x50x6 (21/2x2x1/4) unequal angle section joint
65x65x6 (21/2x21/2x1/4) equal angle section joint
70x70x7 (23/4x23/4x5/16) equal angle section joint
75x50x6 (3x2x1/4) unequal angle section joint
75x75x7 (3x3x5/16) equal angle section joint
80x60x6 (31/4x21/4x1/4) unequal angle section joint
80x80x8 (31/4x31/4x5/16) equal angle section joint
80x80x10 (31/4x31/4x3/8) equal angle section joint
90x90x9 (31/2x31/2x7/16) equal angle section joint
100x65x6 (4x21/2x3/8) unequal angle section joint
100x80x8 (4x31/4x3/8) unequal angle section joint
100x100x8 (4x4x3/8) equal angle section joint
25x3 (1x1/8) flat bar joint
25x4 (1x5/32) flat bar joint
30x4 (11/4x5/32) flat bar joint
30x5 (11/4x3/16) flat bar joint
35x4 (13/8x5/32) flat bar joint
40x5 (11/2x3/16) flat bar joint
50x5 (2x3/16) flat bar joint
60x6 (21/4x1/4) flat bar joint
60x10 (21/4x3/8) flat bar joint
80x10 (31/4x3/8) flat bar joint
80x12 (31/4x1/2) flat bar joint
76x38 (3x11/2) rectangular channel section joint
102x51 (4x2) rectangular channel section joint
127x63 (5x21/2) rectangular channel section joint
152x76 (6x3) rectangular channel section joint
Ductmate™ 30mm (11/8) flange
Ductmate™ 40mm (11/2) flange
Verromez™ 20mm (3/4) flange
Verromez™ 30mm (11/8) flange
Verromez™ 40mm (11/2) flange
