HVAC
Administrator Guide
User Defined Components
Tutorial Style Exercise
: Testing
Testing
When the Geometry, Point Set, Data Set, Detail Text and PLOT are complete it is advisable to do some testing:
Level6, level4, level9, level7 - Make sure the Design element displays correctly, each time combined with holes on/off, insulation on/off
Test that implied tube displays correctly when a following item is moved to create a gap.
Test that the automatic fill with straights utility works as expected when the new component is used in the branch
Test that the HVAC Spooling and Sketches functionalities work as expected and produce good data on the final sketch.
