HVAC
Administrator Guide
User Defined Components
Tutorial Style Exercise
: Create a PLOT
Create a PLOT
When the component looks OK in MODEL, create an example element that can be used on a DRAFT drawing to make a Plotfile.
Create the drawing in a similar style to the standard Plotfiles, where the philosophy was to do a Plan and elevation and an Isometric view giving all the data as on the Properties input form. There is a standard HVAC representation rule available in the DRAFT database that can be used to do a detailed Level 9, holes ON drawing.
The Plotfile should be named the same as the CATREF.
The PLOT property attributes:
Type DATA
Dkey PLOT
Ptype LPLT
Pproperty ( ATTRIB FLNM OF CATR )
Dproperty ( 'HVACADV' )
Purpose PLOT
Dtitle Plotfile
Lhide false
Pproperty is the name of the file.
Dproperty is the name of the directory within the
%AVEVA_DESIGN_PLOTS%
directory.
