HVAC
Administrator Guide
User Defined Components
Tutorial Style Exercise
: Model Set Design Parameters
The component is already in a state where it can be created in MODEL or PARAGON although the Geometric representation will be not correct.
If working in MODEL use the Create User Defined HVAC Fittings form to create an instance of the new component i.e. select the element, set some property values, and apply the form.
If working in PARAGON create a macro to set the model Design Parameters, such as:
model set des para 1 0
Repeat for 100 parameters set to 0
model set des para 2 900
model set des para 3 700
model set des para 4 600
model set des para 5 700
model set des para 41 500
model set des para 42 700
model set des para 7 150
model set des para 10 200
model set des para 12 150
model set des para 13 150
model set des para 63 90
-- 21 to 29 for Joints
model set des para 21 50
model set des para 22 50
model set des para 23 5
model set des para 24 50
model set des para 25 50
model set des para 26 5
model set des para 27 50
model set des para 28 50
model set des para 29 5
DESP[21] to [29] are reserved for the Arrj, Leaj and Bjnt
In MODEL these could be set by command line using desp n21 50 desp n22 50 desp n23 5 etc. However…
For Joints Settings in MODEL: When the element is created, modify the joints using SHOW !!HVCJOINTMOD
