HVAC
Administrator Guide
User Defined Components
Tutorial Style Exercise
: Pre Conditions
Pre Conditions
It is assumed that the Administrator is already a competent Cats&Specs user, comfortable with creating and editing macros to create the necessary database elements.
The Catalogue and Specification work covered in this tutorial can be done in the MODEL or PARAGON module. Since the work is mainly command line and macro driven, it is recommended to use MODEL with Read/Write access to the catalogue. To do this the Administrator should work in a project with such access rights, and then update the final project using macros.
In ADMIN, set MODEL module to Read/Write catalogue:
EDIT MODULE DESI MODE CATA RW
In ADMIN, also create a catalogue database separate from the AVEVA Solutions Limited database, in which to create the User Defined Cats&Specs
