HVAC
Administrator Guide
DRAW Sketches
HVAC Sketch Object
: Backing Sheet
Backing Sheet
This is a typical backing sheet.
The new HVAC Sketch will reference the 'Backing Sheet', which is generally user-defined.
This is a standard backing sheet which will contain the drawing title block, with drawing data displayed via intelligent text e.g. #DATE<FR DRWG> and #:UDA_Name etc.
In addition to the standard title block, the backing sheet is used to identify and locate 'TABLES' that are to be used on the HVAC Sketch.
These tables are identified by:
Material Take Off
- function 'MTO'
SpPurpose 'TABLE'
/ SpPurpose 'CELLS
Assembly
- function 'ASSEMBLY
SpPurpose 'TABLE'
/ SpPurpose 'CELLS
End Points
- function 'ENDPOINT
SpPurpose 'TABLE'
/ SpPurpose 'CELLS
