The Search list displays the project identifiers and project codes that match the characters typed in the field.
Select the check box to display masked projects in the Project field.
Select the check box to enter AVEVA E3D™ using read only mode, the projects can be viewed but not modified.
Select the check box to restore the work area layout to the default settings when entering AVEVA E3D™.
The AVEVA Login window displays, asking you to confirm the deletion of the existing design settings and design window settings files.
