Equipment
Equipment : Modify : Sub-Equipment Origin
Use the Modify SUBE Origin window to change the origin point of a Sub-equipment item, make sure the correct element is selected in the Model Explorer.
Use the Modify SUBE Origin window to modify a Sub-equipment origin using explicit position values.
From the drop down menu, click to identify the direction of the East/West axis. Enter an explicit position value in the Position field.
From the drop down menu, click to identify the direction of the North/South axis. Enter an explicit position value in the Position field.
From the drop down menu, click to identify the direction of the Up/Down axis. Enter an explicit position value in the Position field.
Click Apply to modify the origin point or Cancel to discard any inputs and close the Modify SUBE Origin window.
