Equipment
Equipment : Modify : Electrical Components
The functionality available from the Create Electrical Component window enables a electrical component element to be repositioned and reorientated, make sure the correct electrical component element is selected as the CE in the Model Explorer.
The Create Electrical Component window is displayed and is automatically populated with the properties and attributes of the CE as default. The functionality of the Create Electrical Component window has been previously described, refer to Electrical Component for further information.
To select another CE, select the correct element is selected in the Model Explorer, then from the Create Electrical Component window, click CE. The Create Electrical Component window is automatically populated with the properties and attributes of the newly selected CE.
