The functionality available from the Modify Nozzle window enables a nozzle element to be modified, repositioned and reorientated, make sure the correct nozzle element is selected as the CE in the Model Explorer.
Click parameters to display the Primitives window, indicating the Parameters fields along the axis for the currently selected primitive. Refer to
Nozzle for further information.
Use the Datum part of the
Modify Nozzle window to define the datum point for a nozzle. The functionality available from the
Datum part of the
Modify Nozzle window is identical to that available from positioning control. Refer to COMMON for further information.
The Position part of the
Modify Nozzle window allows each nozzle to be explicitly positioned with respect to (wrt) another element. The functionality available from the Position part of the
The Rotate part of the
Modify Nozzle window allows the user to rotate a nozzle about an axis. The functionality available from the Rotate part of the
The Align with P-Point part of the
Modify Nozzle window allows the user to align the current element with a P-point on another element. The functionality available from the Align P-Point part of the
Modify Nozzle window is identical to that available from positioning control Refer to COMMON for further information.
Click Select Nozzle to select a nozzle using a cursor pick in the graphical view. The
Pick Nozzle : prompt is displayed.
Click Next to modify the nozzle, the
Create Nozzle window displays as default. Close the
Modify Nozzle window to discard any inputs.
