Use the functionality to create a cylinder primitive (CYLI) element, refer tor Cylinder Primitive for further information.
Use the functionality to create a cone primitive element (CONE), refer to Cone Primitive for further information.
Use the functionality to create a snout primitive element (SNOU), refer to Snout Primitive for further information
Use the functionality to create a pyramid primitive element (PYRA), refer to Pyramid Primitive for further information.
Use the functionality to create a dish primitive element (DISH), refer to Dish Primitive for further information.
Use the functionality to create an extrusion primitive element (EXTR), refer to Extrusion Primitive for further information.
Use the functionality to create a revolution primitive element (REVO), refer to Revolution Primitive for further information.
Press the down arrow key and select Two Points to create a box primitive with two specified points (first and opposite corners).
Press the down arrow key and select Three Points to create a box primitive with three specified points (first, opposite and height).
Press the down arrow key and select Four Points to create a box primitive with relative positioning functionality, with four specified points (origin, X, Y,Z).
Press the down arrow key and select Explicit to create a box primitive with absolute positioning functionality, in this case specified origin, width, length and height.
Press the down arrow key and select Radius to create the curved part of the cylinder primitive with a specified centre point and radius.
Press the down arrow key and select Two Points to create the curved part of the cone primitive with two specified points (diameter start and end).
Press the down arrow key and select Explicit to create a cone primitive with an absolute positioning functionality, in this case specified origin, D-top, D-bottom and height.
Press the down arrow and select Centre+ to create the curved part of the cone primitive with a specified centre point and radius/diameter point.
Press the down arrow key and select Radius to create the curved part of the cone primitive with a specified centre point and radius.
Press the down arrow key and select Back to undo the action.
Press the down arrow key and select Two Points to create the curved part of the snout primitive with two specified points (diameter start and end).
Press the down arrow and select Centre+ to create the curved part of the snout primitive with a specified centre point and radius/diameter point.
Press the down arrow key and select Radius to create the curved part of the snout primitive with a specified centre point and radius.
Press the down arrow and select Two Points to create the base of the pyramid with two specified points (first and opposite corner).
Press the down arrow key and select Two Points to create the base of the dish primitive (diameter start and end).
Press the down arrow and select Centre+ to create the curved part of the dish primitive with a specified centre point and radius/diameter point.
Press the down arrow key and select Radius to create the curved part of the dish primitive with a specified centre point and radius.
Press the down arrow key and select Knuckle Radius to create the transition between the cylinder and dish (knuckle).
Press the down arrow key and select Diameter to create the inside/outside radius of the circular torus primitive with a specified origin and diameter.
Press the down arrow key and select Two Points to create a rectangular torus primitive (diameter start and end).
Press the down arrow key and select Explicit to create a rectangular torus primitive with a specified origin, start angle, sweep angle, inner radius, outside radius and height.
Press the down arrow key and select Width of the rectangular torus primitive.
Press the down arrow key and select Centre+ to create a rectangular torus primitive with a specified centre point and a radius.
Press the down arrow key and select Two Points to create the base diameter of the sloped cylinder primitive (diameter start and end).
Press the down arrow key and select Explicit to create a sloped cylinder primitive with absolute positioning functionality, in this case specified origin, base diameter and height.
Press the down arrow key and select Radius to create the base diameter of the sloped cylinder primitive.
Press the down arrow key and select Centre+ to specify the base centre of the sloped cylinder primitive.
Press the down arrow key and select Finish to end the process.
Use the functionality to create a negative box primitive (NBOX) element, refer to Box Primitive for further information.
Use the functionality to create a negative cone primitive (NCONE) element, refer to Cone Primitive for further information.
Use the functionality to create a negative snout primitive (NSNOU) element, refer to Snout Primitive for further information.
Use the functionality to create a negative pyramid primitive (NPYRA) element, refer to Pyramid Primitive for further information.
Use the functionality to create a negative dish primitive (NDISH) element, refer to Dish Primitive for further information.
