Input a design point number into the Number field. Alternatively, select Next Available to display the next available design point number by default.
Enter a description into the optional Description field.
Enter a function into the optional Function field.
Enter a purpose into the optional Purpose field.
Enter a design point connection direction, for example, input U in the Direction of Design Point (Z) field to direct the design point to face the U axes.
Positions the design point using a cursor pick in the graphical view. The prompt Define Position (Distance[0]) Snap: is displayed.
The Positioning Control window is displayed by default, refer to Positioning Control for further information.
Selects the position axis from the Position drop-down lists, choose from East/West, North/South and Up/Down. Enter the explicit position values in the Position fields.
Input a design point number into the Number field. Alternatively, select Next Available to display the next available Design Point number by default.
The prompt Define Position (Distance[0]) Snap : is displayed. The Positioning Control window displays by default. Refer to Positioning Control for further information.
Selects the position axis from the Position drop-down lists, choose from East/West, North/South and Up/Down. The user can then input the explicit position values in the Position fields.
The prompt Define Position (Distance[0]) Snap : is displayed, the Positioning Control window displays by default. Refer to Positioning Control for further information.
