Equipment
Equipment
: Import-STL
Import-STL
STL format provides an approximation of a curved surface model, with accuracy and level of detail controlled through a tolerance setting. Import-STL maps this format onto AVEVA 3D primitives. Hence a 100% accurate translation of the source model into AVEVA E3D™ geometry cannot be guaranteed.
Import-STL is for translating stereolithography (STL) files, that have been generated from non-AVEVA Mechanical CAD systems, into macro files that can be input to AVEVA E3D™.
The input to Import-STL consists of STL files generated from/by non-AVEVA Mechanical CAD systems. Some non-AVEVA Mechanical CAD systems have an inbuilt facility for generating STL files, others do not, and the generation of STL files from these systems involves the use of a separate translator program, such as CADfix® from ITI TranscenData (http://www.transcendata.com).
The STL files normally have the extension .stl and can be either ASCII or binary in format. Import-STL reads both ASCII and binary STL files.
The Import-STL program works in read-only mode and the original STL files are not changed in any way.
The output from Import-STL consists of a macro file that is suitable for input to the MODEL module of AVEVA E3D™.
Solid Polyhedron
The definition of the Solid Polyhedron is a set of faces that have to make a complete solid, for example, all edges of the faces have to have corresponding edges from other faces. The Solid Polyhedron has the following characteristics:
It is more economical to store in DESIGN databases than a corresponding POHE/POGO arrangement.
It is faster to manipulate in the MODEL module.
The clash detection is better than POHE/POGO because it can detect parts that are completely inside the polyhedron.
It allows the use of invisible edges which is a facility that:
Edges are not displayed in wireline mode in MODEL.
In colour-shaded mode in MODEL the parts are displayed with smooth shading between faces that share invisible edges.
Drawings produced using DRAW show the visible edges and any silhouette edges only.
By default Solid Polyhedron generation is switched on.
