Design Templates
Select Design Template
: Create a Template Reference in a Specification
To create a Design Template reference in a specification, the user must enter the Catalogue Explorer. The user can then modify an existing Specification (SPEC) by creating a new Specification Component (SPCO) and defining the Tmpref attribute to reference the Design Template.
On the
Home
tab, in the
Navigate
group, click
Catalogue
to display the
Catalogue Explorer
The user can navigate to the Specification Selector (SELE) and create a Specification Component (SPCO).
For example, to create a new SPCO in the Panel Fittings Specification, navigate to
MASTER/STLCATA > SPWL STRUT/PENI/SPEC > SELE 1 > SELE 3
To create a new SPCO using the Command Window, on the
Home
tab, in the
Windows
group, click
Command Window
to display the
Command Window
To create a new SPCO named
KICKPLATE
input the following command into the
Command Window
NEW SPCO /TMPL/SAMPLE/KICKPLATE
The modify the
Tmpref
attribute to
KICKPLATE-1,
Command Window
TMPREF /Kickplate-1
The template now exists in the Design database and a new specification component, pointing to the template, is added into the Catalogue database.
The user can enter the Structures application and create a Panel Fitting by selecting KICKPLATE from the list of available Fitting Specifications. Refer to
Structural Design User Guide
, for further information.
