Design Templates User Guide
Tools : Search Templates
On the Design Templates tab, in the Tools group, click Search Templates to display the Design Template Search window.
Click Show All Templates to display all design templates in the current MDB.
Click Search to list the Design Templates matching the criteria.
The user can export the search results of the Define Template Search window to Excel. Right-click the selected Design Template in the search results list and select Export to Excel to display the Save As window.
The user can print preview the search results of the Define Template Search window. Right-click the selected template in the search results list and select Print Preview to display the Print Preview window.
The user can filter the search results of the Define Template Search window. Navigate to the blank row under the heading row of the search results list to display the filtering controls.
The user can input a value in the Filter Criteria field to refine the search criteria.
The user can define the templates to filter and select Text Filters to refine the search criteria. Click OK to filter the search criteria or Cancel to discard any inputs and close the filtering controls.
The user can group the search results of the Define Template Search window. Navigate to the blank row under the heading row of the search results list to display the filtering controls.
Select a Column Header, for example Name, and drag and drop the selection into the Drag a column header here to group by that column field.
