Click Create > Cartesian Point to display the Create - Cartesian Design Point window, refer to Create Cartesian Design Point for further information.
Click Create > Cylindrical Point to display the Create - Cylindrical Design Point window, refer to Create Cylindrical Design Point for further information.
Click Create > Spherical Point to display the Create - Spherical Design Point window, refer to Create Spherical Design Point for further information.
Input a Design Point number into the Number field. Alternatively, select Next Available to display the next available Design Point number by default.
The user can input a description into the optional Description field.
The user can input a function into the optional Function field.
The user can input a purpose into the optional Purpose field.
Input a design point connection direction, for example, input U in the Direction of Design Point (Z) field to direct the design point to face the U axes.
The user is prompted to Define Position (Distance[0] Snap:
The Positioning Control window displays by default, Refer to Common Functionality User Guide for further information.
Select the position axis from the Position drop-down lists, choose from East/West, North/South and Up/Down. The user can then input the explicit position values in the Position fields.
The user is prompted to Define Position (Distance[0] Snap :
The Positioning Control window displays by default, refer to Common Functionality User Guide for further information.
